I am looking for any input on locating a reasonably priced set of expanding mandrels for lathe work. I am looking for the type that are held between centers, and vary in size from 1/2" to 2". Thanks!
Arbo & Thor (The Junkyard Dog)
Expanding mandrels? They're not very accurate, they don't hold well, and their closest proximity ro accurate holding is near their minimum size.
As expanding mandrels expand they go hour-glass shaped meaning they grip the work on the corners of the bore. The work has to be manually centered for grip as the tapered part of the mandrel is thrust in. If you sock it home the waist of the hour class deforms and holds moderately well provided any thrust is in the direction of hold.
Expanding mandrels are convenient but I'd never trust them for accurate work or work on which I had to do much machineint. I'd rather make a spud expanded with a screwed in pipe plug as time consuming and expansive as that is than trust an expanding mandrel.
The last time I saw expanding mandreals used in a production setting was for aligning, spacing, and welding on water tight door inges.
On the other hand I'd love a set of chilled iron solid mandrels by 1/16" from 3/8" to 2 1/2". Fat chance. They were expensive even back when they were used a lot.
I just always use a temporary self locking mandrel, better accuracy. Are you aware how to make one?
Michael
I have a fair assortment of KO Lee expanding mandrels that are held between centers.
They aren't cheap.
I use them for tool grinding, among other uses. I believe they're quite accurate over their complete range of expansion, I'm sure they're well with .001" TIR.
The story is, this guy is hot-rodding a big F-250 for pulling competition. He is fabbing up some sort of dual clutch system. What is happening...the mounting hub in the clutch plate gets removed. Chuck it in the lathe, and removed splined hub area from the center. Then, weld in a larger splined hub. Then, return to the lathe...hopefully mounting said splined hub on some type of arbor or mandrel mounted between centers, and taking a truing cut on all outside surfaces. The clutch plate and hub assembly will then be reassembled together, and installed in the truck. The only part I have in this is the actual welding and machining. Another experienced machinist friend told me that an expanding mandrel would be the way to go. I have never used one, but it sounded promising to me. If I could get a piece of the splined shaft, that would work with some locking collars, but the customer tells me that isn't possible. Any other ideas to mount this thing up for a truing cut would be appreciated. The way I see it, I need to count on the ID splines to ensure concentrcity on the OD of the part.
This set doesn't reach 2" but is it what you had in mind?
http://cgi.ebay.com/Lathe-expanding-...QQcmdZViewItem
I think Enco has a set up to 2" but it's around $500
[This message has been edited by johnc (edited 07-15-2005).]
Make your self an alignment shaft out of bar stock. Turn piece to fit snugly in hole in clutch hub .. If a spline is needed mill a couple ok slots in your shaft then make a key to fit the hub Jim
jim
It would be better to build/machine a fixture to hold averything in location as you weld it.
Forrest,
Does that include the KO Lee mandrels? Probably so, but they seem to bring enough on Ebay that I always figured they had to be pretty good.<font face="Verdana, Arial" size="2">Expanding mandrels? They're not very accurate, they don't hold well, and their closest proximity ro accurate holding is near their minimum size.</font>
Mike Henry near Chicago
http://www.kolee.com/mandrels.htm
These are accurate and grip parallel. They are not for heavy cuts, but will serve the purpose when used properly. I think they are more suitable to grinding than lathe work.
They are expensive. It is usually easy enough to make a dedicated expanding arbor for the job at hand. It will be just as accurate, or better. The price is right, and you will have it in 15 minutes.
