Results 1 to 10 of 16
Thread: Plastic question?
    May 2004
    Vancouver, Wa
    Question Plastic question?
    Does anyone have a connection to buy machinable plastic rods like delrin only cheaper? What are some cheaper alternatives to Delrin or Acetal. I will be making some rollers or shives for my new anchor holder design I need to get some 3.5" dia x 7" long material or multiples of that demention that I can cut to size and bore a .5" hole.
    On the Oil Coast
    I have in the past used a couple different companies,but they were either neck and neck with McMaster-Carr or more expensive,so I quit them and went with McMaster.
    Dec 2002
    There is always lots of Delrin at ebay in small quanities.
    Michael
    Mar 2004
    SE, Michigan
    hdpe (high density polyethylene) is probably cheapest that i can think of
    On the Oil Coast
    I have had good luck with these guys in the past-
    http://www.piedmontplastics.com/
    Just for refrence,here are the part numbers for McMaster-Car UHMW 8701K57 HDPE 8624K48 DELRIN 8512K35
    Notice the compressive strengths,quite a bit of difference in the three.
    Swarf&Sparks Guest
    I'll stand correcting here, but I think Delrin is a trade name for acetal-homopolymer. Made some sliding bushes for a small machine. Delrin was big $$$$, generic acetal a lot less spendy. I'm in West Oz and dealt with a company in Qld called small bearings (Or similar). They deal with, largely, a hobby/modeller market. Service was great, delivery quick.
    Not suggesting you deal with em, just that the plastic is the same and has worn well.
    Rgds, Lin
    52N 122W Western Kanuckistan
    Gundog,
    Try pricing Nylatron. It is moly filled structural nylon and is tough as nails. The moly filling gives it lubricant properties. I find the best way to bore it is with a spade bit. This gives plenty of chip clearance and doesn't bind or produce much heat. This part was drilled with a spade bit.
    May 2004
    Vancouver, Wa
    Thanks for all of the replies. I am trying to start a small business with my new product I have created. I am trying to put a cost together per unit to see if this will be worth taking on and Delrin which is a trade name from Dupont (I think) is the same as Acetal I found this out reading some info from machinist-materials. I will research the info from here to see what I can find out.
    Nov 2004
    Tipp City, Ohio
    You can go to these guys
    http://www.atlasfibre.com/
    My understanding is that they are the one of the largest producers of delrin plastic sheets and rods. The purchase the raw material for plastic from Dupont or who ever and then make it.
    I dont know about minimun quantity etc.
