Results 1 to 9 of 9
Thread: Vacuum Chucks
    Apr 2002
    Question Vacuum Chucks
    Has anyone ever built a vacuum chuck? How
    is the amount of vacuum controlled?
    Maine
    Can't help you, at all, on this one! I would think one could use some kind of a "bleeder" valve to control the amount of vacuum, i.e. a controlled leak.
    Jul 2001
    Typically the amount of vacuum is constant on a chuck. The amount of holding force is directly proportional to the surface area of the work piece. You can buy a vacuum generator that works off of compressed air out of Mc Master Carr for less than $100. After that you need only build a two piece device that acts as your chuck. Since a picture is worth a 1000 words email me and I will send a photograph and detailed discription to you.
    C. Tate
    Mar 2002
    Kirkland, Washington
    built several. The thing to remember is holding force is controlled by the inches of Mercury (in/Hg)produced and more important maintained as well as the surface area. The tighter the seal the lower volume needed. I have used a compressed air vacuum generator. They work fine, but your air compressor is going to work also. I have bought small vacuum pumps. They are somewhat spendy, but you are not running your air compressor. I have scrounged them from print shops and dentist offices. The "whipmaster" from the dentist office would "suck a golf ball through a garden hose", kinda like a girl I used to know.
    I also used a three pin fence on most parts to get repeatability of location and to help control lateral movement.
    Remember you cannot drill/mill into holding chamber.
    May 2001
    Wink
    Hey, Step...I knew that same girl! Small world.
    Jul 2001
    You better stop talking about that girl somebody may get offended and tell Neil that you are being crude and suggestive. I knew her too.
    CT
    Stepside:
    I don't think I should tell you about the 10HP 3Phase 4" inlet vacuum pump I sold awhile ago - it really, really sucked.
    Vacuum chucks work well on the mill and grinder, I have never seen a rotary one for lathes (the rotary vacuum interface would be expensive). Wood workers have used vacuum for laminating and work holding for 20 years.
    Mar 2002
    I have built some vacuum patterns for router work that are 4 by 5 feet. When they are that big it really holds. Remember that force equals area time pressure difference.
    Feb 2002
    I've been pricing Tri-Vacs on ebay because I have one I'm deciding whether to sell or keep and I notice two just ended with no bids and very reasonable start prices...
    Item #'s
    1778081065
    1776705840
    This one is very reasonable and may be a steal:
    1776695484
    There's a couple others on ebay...just thought you may be interested...at this point it looks like I'm keeping mine!!! Don't think I'd get enough to make it worth re-acquiring one when I need it.
