<font face="Verdana, Arial" size="2">Originally posted by Mcgyver:
...So assuming ball bearings are reasonably accurate and priced, a suitable non magnetic tube can be found, and whatever you are doing with the ttl output exists or is assumed, any thoughts on how to build one?</font>
The problem is: The TTL output that you mention is the result of the processing done by the DSP. This is definitely non-trivial. I've designed many similar systems, and I can tell you that it takes some very good engineers and programmers to make something like this work, and considerable $$$.
Leigh
The entire content of this post is copyright by, and is the sole property of, the author. No assignment
of title nor right of publication shall ensue from presentation of this material on any computer site.
