Results 1 to 6 of 6
Thread: OT - any old controls geeks know the RCA HC2500?
    Post OT - any old controls geeks know the RCA HC2500?
    This is a hybrid op-amp which was popular for driving FHP DC servomotors back when Analog was King. It's a relatively high-power device - something around 20V and 6 amps, maybe - but I'm still afraid that I'll fry something if I try to figure out by guess and by gosh just how those ten pins connect. Anyone have a line on a data sheet?
    May 2005
    You can get the data on
    CDROM from
    http://www.ecadata.de/searchnew/
    I don't know what the cost will be, you can open an account and find out - regards, Peter
    Try 75V and 7 amps.... max ratings, subject to safe operating area of output devices......
    0.5% thd 30 kHz bandwidth.......
    1 -V (-V power) (called drive1)
    2 -V (-V input circuitry)
    3 output
    4 +bias adjust
    5 frequewncy comp
    6 - input
    7 +input
    8 - bias adjust
    9 drive2 upper output emitter
    10 +V
    There was a related device, the HC2000H, which has a different pinout, and includes various protection facilities.
    You got some of these critters?
    I have teh data sheet for the two in a catalog..... and access to a copy machine.....should you be interested.
    There aren't any apps circuits with it, but I MAY be able to scare that up from another source.......
    [This message has been edited by J Tiers (edited 10-12-2005).]
    You might try: www.thegeekgroup.org
    No, these are NOT the idiots you see on TV!
    Regards, Greg B.
    If you\'re data is anomalous, you\'ve more digging to do.
    Excellent, thanks, those pin assignments are the ones I was looking for.
    I have a couple of these amps on small circuit boards. I have traced out most of the circuitry, and they're conventional difference amplifiers, although I haven't yet puzzled out some peculiarities in the velocity feedback circuit. These boards drove an x-y positioning table in a machine which printed the circuit patterns on silicon wafers, which would later be sawed up and packaged as processors and large memory chips - all very high-tech, or rather the high tech of twenty years ago.
    The motors are Electro-Craft 576 permanent magnet DC servomotor-tach combinations. I've lost the data sheets for those, too.
    SOMEwhere, I have an Electro-Craft book or two.
    Should at least have specs, maybe more.
    I'll look around.
