Results 1 to 2 of 2
Thread: More rust cleanup, phosphoric, this time
    Post More rust cleanup, phosphoric, this time
    There having been so much on the electrolytic de-rusting method, I thought I should post a pic of the results of derusting with phosphoric acid....
    The two items in the pic were "balls of rust", that is there was rust on all surfaces. I knocked off the loose rust, and dunked in phosphoric for a couple hours.
    A minimal amount of brushing and this is the result. Should have taken a "before" pic, but didn't think about it then.
    Product used was "Savogran Crete-Nu", diluted several to one in tap water.
    Slight yellow tinge is visible, which is not rust, but a coating that the phosphoric tends to create.
    [This message has been edited by J Tiers (edited 10-15-2005).]
    Hi There,
    I knew a High School Chemistry teacher that used Oxalic acid for removing rust. I tried it and it works okay. Anybody else tried this?
    BTW, your results look good!
    -Blue Chips-
    Webb
