Results 1 to 3 of 3
Thread: Test Dial Indicator
    Oct 2005
    Post Test Dial Indicator
    I picked up a Brown and Sharpe Test Dial Indicator and it didn't come with instructions on how to use it.
    I am hoping someone can give me some help.
    Thank you,
    the_spaws
    Ron LaDow Guest
    Assuming it's all there, there's a 'tail' that moves when the body is held stationary. When the 'tail' moves, the needle rotates around the dial.
    As to what you you use it for, there's all sorts of alignment, concentricity and height tests where it is very handy.
    Thanks,
    Ron LaDow
    Aug 2001
    Mid Michigan
    Maybe some of the information at this site will be helpful.
    http://www.mini-lathe.com/Measuremen...l%20Indicators
