Results 1 to 9 of 9
Thread: HELP!! The metal must be shaped!!
    May 2004
    Post HELP!! The metal must be shaped!!
    I am pulling my hair out. I got my new lathe all ready to go and can't find a motor for it, well I can for 750 bucks. Does anyone know where to get used motors or cheap motors. I need either a 5hp 220 single phase 3600rpm or a 3hp 220 3phase 3600rpm. HELP.
    Oct 2004
    Ellaville, Ga
    Calm down Flash!
    Put on some Allman Brothers and turn the lights down. You may want to lie on the floor with an ice cube on your head. (It helps me sometimes)
    We need to know what frame the motor is.
    Deep Sea Tool Salvage
    Deep in the Heart of Texas!
    Have you tried Surplus Center?
    http://www.surpluscenter.com
    Harbor Freight now has 3hp motors that were previously sold as 5hp. Less than $100.
    Oct 2001
    As Hoffman pointed out, no can help with so little information.
    What frame #?
    Motors of that size bounce around ebay for chump change all the time.
    Something like this?
    http://cgi.ebay.com/NEW-5-HP-3450-1-...temZ7555577266
    Or this?
    http://cgi.ebay.com/3-HP-3450-RPM-Si...temZ7555072697
    James Kilroy
    Aug 2005
    Maryland
    Grainger http://www.grainger.com lists a 3HP fully enclosed fan-cooled 230v 3ph made by GE for $283 under their catalog number 4RZ57. And many other motors.
    Leigh W3NLB
    Leigh
    The entire content of this post is copyright by, and is the sole property of, the author. No assignment
    of title nor right of publication shall ensue from presentation of this material on any computer site.
    Bremerton Washington
    Look in the yellow pages (the paper ones) under "electric motor." Call around your local motor shops and ask for leads to the motor you wish to find.
    $750 is highway robbery for the motors you listed. Also why 3600 PM? Most machine tools are powered with 1800 (1750 actual full load RPM) RPM motors.
    As it happens I have a 230 volt single phase 5 HP 1750 RPM 215 frame motor but Seattle to Ontario shipping a 100 + lb motor will kill the bargain.
    You can buy a 3 HP VFD and motor as a packaged pair from Dealer's Electrics for $500 US or so. Look on the home page. Ontario is not that far from NYC. Maybe take a weekend trip with the family.
    http://www.dealerselectric.com/
    [This message has been edited by Forrest Addy (edited 10-19-2005).]
    May 2004
    Any horizontal frame will do. I need the 3600rpm because that is what was on the lathe. It was actually a 2 speed 1740 and 3450rpm. I want to go with the high speed. I guess I could change the pully. The last one that jkilroy pointed out looks good. I asked if he could ship to canada.
    On the Oil Coast
    Two speeds huh,well you may end up losing half of your speed changes if you go to a single speed motor.Least that's the way Hardinge does it.They use a two speed motor to give instand lo/hi capability which is nice if you do much drill and tap work in the lathe.
    Oct 2004
    Shuswap, BC
    You should be able to get a Baldor motor for a fraction of that price. I have a Harrison Lathe, that came with a 3HP 2 speed, 50 hz, 415V 3 Phase motor. I had single phase 220V available. A phone call to a knowledgable friend, and I have a 3hp 220V 3ph motor and a Baldor Frequency inverter. Problem solved. Now I need a tachometer for the spindle.
