Results 1 to 2 of 2
Thread: Anyone know details about European, "Swiss," or "Geneva" style watchmakers lathes?
    Post Anyone know details about European, "Swiss," or "Geneva" style watchmakers lathes?
    I have an 8 mm Lorch "German," pre WWII, and maybe pre WWI, with numerous accessories. The headstock pulley has a series of small holes around perimeter, that, normally, I think, are similar to ones found on American WW lathes, for engaging a spring loaded pin, to stop pulley travel along those holes. However, this lathe has no pin, no hole for pin, no nothing that I can see, for engaging those holes, so what are those holes for? They are very small pin holes.
    The holes are almost certainly used for indexing I.E with this you can stop the lathe at predetermined and even spaces.It allows you with the aid of an overhead cutter to cut flats, gears, etc, etc,with your lathe in effect to mill on the lathe.Let's say you wanted to cut some gears you dont want to have to measure each cut every time with these stops using the indexing pin you can hold the collets steady and make a cut etc etc I am sure you will find a better explanation given than mine but that is the basic idea .making a small pin should be no problem regards Alistair p.s does the lathe have a model number or do you have photo's
