Results 1 to 6 of 6
Thread: Drill bits, Bright or Surface treated finish?
    Question Drill bits, Bright or Surface treated finish?
    What are Bright finish drill bits used for and what are surface treated finish drill bits used for?
    J&L has a set on sale that I am interested in and it is the same price for the Bright or the Surface treat finishs. I am just learning about machining and tend to do more farm machinery repairs with the drill bits.
    Maine
    I've used both and never noticed a whole lot of difference, although I haven't paid much attention, either.
    I've been using a set of surface-treat 135 degree split point screw machine length drills lately, and like them a lot. I've also got sets of bright 118 degree fractional, number, and letter drills, and they work well too.
    I think the main thing is to get good-quality bits, whichever kind they are. Poor-quality drill bits are useless, and you'll have to end up buying good ones, anyway.
    Portland Oregon
    The black surface treated drills are for steel, polished drills are for aluminum and other non-ferous materials, at least that's what the catalogs say. Funny thing, the outfit I work for deals mostly with aluminum, yet almost all our drills are black. I think they're just more commonly available.
    Jul 2001
    I tend to think the same as Randy, The polished drills are supposed to keep soft gummy materials from sticking to cutting edge. I have both in my drill index and I cannot tell the difference.
    Thanks for the replies.
    I will go with the black surface treated drill bits since I rarely drill soft materials like Aluminum.
    If you want a good set of drills get a set of 135* splitpoints. I have a set of Norseman "high moly alloy" that go through 304 stainless like a hot knife through butter in Mexico! The drills have a bronze color (TiAlN ?). Excellent drills (made in St. Paul, Minnesota). I like their taps & dies (same alloy as their drills) better than my Osborne Warrior & Blue Wizard taps.
    The polished flutes are "supposed" to help draw chips out of deeper holes - less friction. The coatings (TiN, TiCN, TiAlN, and Diamond film) they use these days make a big difference for mass production and resulting tool life. Their hardness and high heat resistance improves edge life even with carbide tooling.
