Results 1 to 5 of 5
Thread: Mill cut geometry?
    Ron LaDow Guest
    Question Mill cut geometry?
    I need to cut a taper into an existing straight hole, the taper centerline being, say, 6* deviant from the hole centerline. The taper is, say, 14* included angle.
    The existing hole is 32mm (~1.25) and the cut surface is probably 1-1/4" long at most.
    Material is cast Zn.
    So this is easy enough with a CNC, but I've got a vertical mill and a rotary table. Looks like I need to tilt the head and the rotary table?
    Sep 2005
    Is your * meaning degrees?
    So the existing hole isnn't true to the centreline of the tapered hole you wish to create?
    If I'm understanding things right....and it's a 'fussy' situation, I would tend to leave the head square, clamp the part to the rotary, get everything shimmed, clamped, etc. to get the hole centreline where you want it to be. I would then strongly suggest a 7 degree taper cutter to mill the taper of teh hole....this would be a fair bit more accurate then trying to tilt everything.
    Depending on the part, it might be a possible job for a 4 jaw chuck on the lathe, and use the compound or a taper attachment to create the taper.
    Give us more details, maybe we can suggest a better method for what you are trying to do.
    tattoomike68 Guest
    the easy way is to blast a big strait hole in the part and press in a tapered hole sleave made on a lathe. weld it in if you need too.
    easy as pie
    Jul 2001
    Green Bay, WI
    Ron, You got it !
    Leave the rotary table flat.
    Tilt your head to match the desired taper.
    Just remember (!) , the cutter MUST be on the centerline when cutting. If you move the table(& Saddle ) on the Y axis, that is in or out, You will change the taper from the desired angle to another!
    No Math Approach
    As a help, if you have the pin to fit the hole, and it is straight on its shank, you can bore a hole ( W/Mill) to fit the straight shank in a piece of scrap, then indicate the taper with a dial indicator, untill the head is tilted to match the taper
    Ron LaDow Guest
    greywynd,
    Yes, the *=degrees. Even with a taper cutter, I still need to tilt something since the centerlines aren't parallel. They intersect ~ 2-1/4" below the top surface.
    tattoomike68,
    Can't. There's very little metal around the existing hole and it's zinc.
    Rich,
    Gave it more though and I think I have to tolt the piece on a flat rotary table.
    Thanks, guys, time to make some tools or chips and see what happens.
