Results 1 to 7 of 7
Thread: Best rules of thumb on material planning?
    Nov 2002
    Post Best rules of thumb on material planning?
    I'm trying to figure out how much material to buy for my current project but I realize that I don't have basic rules of thumb to go by, to plan the material properly. I've got to remember to plan for the kerf and since I have some advantage with a computer I wonder if I made some slight adjustment of a dimension here or there, would it result in efficient material usage? Should I buy 10' pieces or 20' pieces even though they will be harder to handle. Should I cut all the biggest pieces first, and then the next biggest?
    Is it even worth planning it out? Is it better to just buy lots of material and have a great scrap pile? (Those were the days.)
    Thanks in advance.
    Spence
    Don't buy too much material because you'll soon realize you'll want to upgrade your saw
    When in doubt, doubt your doubt.
    www.metalillness.com
    Oct 2004
    Northeast Oh-hi-Owe
    Best rule of thumb I have is... BUY MORE THEN YOU THINK YOU NEED. I always purchase more then I plan on using. I always buy in mill lengths as it's cheaper. If I purchase off a list of required materials I always add a piece of each item in case I have a senior moment (cheaper then delivery charges). No matter what you'll use what you've order one way or the other I know I always do.
    52N 122W Western Kanuckistan
    You might try the free 1 dimension stock cut planning program here:
    http://www.astrokettle.com/down1d.html
    Millman Guest
    Wink
    Also consider the facing or milling operation. Maybe each piece gets faced on 1 or both ends. If your saw is cutting out of square on each cut, that multiplies the amount of stock you,ll need. A Good saw will cut .002- .005 out of parellel in a 6" deep cut. If it 's not square, use some dynamite!
    Dave da Slave
    Western New York U.$.A
    <font face="Verdana, Arial" size="2">Originally posted by Tinkerer:
    Best rule of thumb I have is... BUY MORE THEN YOU THINK YOU NEED. I always purchase more then I plan on using. I always buy in mill lengths as it's cheaper. If I purchase off a list of required materials I always add a piece of each item in case I have a senior moment (cheaper then delivery charges). No matter what you'll use what you've order one way or the other I know I always do. </font>
    I use Tinker's way but with this caveat. I always want to have enough scrap to cover any error's and also enough to build a smaller project in the future should I desire. I don't like the pressure of worrying if I'm going to make it with what i got. And, if you've shopped right, it won't likely be any cheaper or convienant to get than it is at this moment.
    I built $4,000 dollars worth of commercial film racks for my employer for $2,000. I ordered double scrap, 300 amp arc welder and a O/A welding setup. I used the double scrap to make a jig to build their heavy duty shelves! I broke even but now had a garage full of scrape and welding gear They saved 1/2 of their money. Took one weekend for a rookie to accomplish it.
    [This message has been edited by Your Old Dog (edited 01-13-2006).]
    sorry, double post somehow...........
