Results 1 to 7 of 7
Thread: Snow blower Project
    Post Snow blower Project
    Hey Guys...
    I have been busy doing this!
    http://bbssystem.com/viewtopic.php?p=4929#4929
    Rob
    Oct 2004
    Akron, Ohio
    Nice job but why not use a 4-jaw and get it dead center? Also when you say the lathe's faceplate was too big I assume you mean the slots were too far apart for the holes to match? I have a faceplate for my Logan that I made I cut concentric grooves every 1/4" in it and just drill it on my rotary table whenever I need to mount something odd.
    -Christian D. Sokolowski
    True happiness is not having what you want but wanting what you have.
    Western New York U.$.A
    Neat project! Now you can walk around with that "I did it myself" feeling which I kinda enjoy. If you work in the trades you may not know that feeling that some of us who don't, do!
    Chris,
    Yeah that is the problem i had. The slots in my face plate were too wide for the part i was making. I am not as accurate with a 4-Jaw right now. I wanted something i could just align once and be done with it. It worked out. I will have to come up with a steel blank that i can drill holes or slot into for my lathe. Another to do item.
    YOD.
    I realy do feel that way. My friends are all amazed but compared to the talent that lies here and other BBS' i feel like small patatoes. Still proud of my work and i know that for me, when i was a newbie, seeing pictures and describing the challenges and success of any project helped.
    Next up is something a little cooler
    Mar 2004
    Looks good. I learned a lot on a similar project with help from these guys.
    Re: scraping the keyway on a lathe
    1. There must be some way to re-tool to get full depth to eliminate the filing. 2. Someone suggested inserting a scrap of shaft in the hub and drilling out all the waste you can first.
    With hindsight always being 20-20 looks like it might be easier to drill and tap the setscrew hole first then center the keyway on it instead of the other way around.
    Re: 4-jaw
    A lot of old machinists have or are using chucks with a million hours and hundreds of crashes on them. A decent, fairly new three jaw should easily produce the accuracy for your project. It's a good idea to check it once in a while though. You will hove plenty of opportunities to learn how to dial in a four jaw without using it when you don't need to.
    Once again well done (and well documented) I sure learned something from it. Thanks.
    Mar 2004
    Re: 4-jaw
    Thanks For the compliment and the hint GKMAN. When i chucked up the part to machine the back it came out to 0.005 TIR. With a little convincing from good old hammer...hehehe I got it to run at 0.002. For me that is great. I do not think it will be a problem at 540 rpms
