Results 1 to 10 of 12
Thread: centrifugal force
    Apr 2005
    fort mcmurray alberta
    Post centrifugal force
    i want to build a centrifugal clutch.. 45 hp.
    aprox 6 inch diameter. i want to engage this clutch at 1000 rpm. with a max speed of 3500 rpm, there will be three steel shoes, lined.
    question.. what kind of spring pressure do i require.. i will use three compression springs..(valve springs) i have a design in mind. but lack the formula...if any one can help me... thanks
    freddy
    15X50 colchester.. 9 inch southbend. milrite, wire feed
    52N 122W Western Kanuckistan
    Apr 2005
    thanks evan.. i came up with 112 is this the weight?
    It is the acceleration factor. 112 means 112 times the effective weight, or 112 gees.
    If the weight of the shoes is one pound at 1000 rpm they will experience 112 times the force meaning a 112 pound spring will be needed, more or less.
    Apr 2005
    good deal thanks again
    freddy
    Did you do the metric conversion right? For a radius of 3" (76.2mm) I get a gee factor of 85 at 1000 rpm.
    Apr 2005
    no.. i entered dia..but 85 is closer to the spring pressure..which is a good thing..
    freddy
    The formula for centrifugal acceleration, a=rw**2, gives 85.27 gravities (r=.0762m, w=104.72 radian/sec), so Evan's number gets my vote.
    As a point of interest the average washing machine generates up to 400 gees in the spin cycle. Some models in Europe produce over 1000 gees. This begs the question of what happens if the cat gets in there?
    Jan 2006
    Keystone State
    A dryer version of what happens to cats when they get sucked into a woodworking dust collector
    Today I will gladly share my experience and advice, for there no sweeter words than "I told you so."
