Results 1 to 10 of 13
Thread: Steel Recomendation
    Dec 2002
    Post Steel Recomendation
    What would be the best grade steel to use for making pins for a small backhoe bucket. Pins will be 1 1/4" dia x 8" to 10" long, drilled and tapped for grease fittings and passages.
    Thanks,
    Frank
    Deep in the Heart of Texas!
    What are the bearings or sleeves made of? If there's no bearings, it's easier to replace a pin than a sleeve. In that case, use a cold rolled or W-1.
    On the Oil Coast
    Induction hardened chrome cylinder rod,failing that B-7.
    I would not use anything that is dead soft,the pins will pound out in an instant.
    On the subject of grease holes,I don't like drilled pins.The cross hole is where those pins always snap.It's much better to put the grease zerks in the working bushing and leave the pin blank.
    tattoomike68 Guest
    <font face="Verdana, Arial" size="2">Originally posted by wierdscience:
    </font>
    I agree with weird, at the shop we would use 4140, we stock that and its tough.
    Jan 2006
    Northern Neck Virginia
    you want a case hardend part for wear resistance in the bushings and meduim hard core to support the case and take the shock loads.
    8620 is perfect for this.
    Well, ok. In my mind I was thinking of a Cad Digger or similar home-grown bucket. ... Like the Kenbota!
    Oct 2001
    4140 pre-hard should work well.
    James Kilroy
    Dec 2002
    Thanks for the tips. I didn't want to use cold rolled, at least without it being case hardened. I was thinking of using 4140 prehardened or the chrome cyl rod, they are both listed in McMaster-Carr.
    The customer definitely wants the grease fittings in the pins (same as original). The grease fittings are at both ends, extending in about 1" to 2" on each side. I could handle drilling in hardened steel, but tapping for the grease fittings could be another story. Are the 4140 prehardened and cyl rod drillable/tapable at the center of the diameter?
    It is a small machine. The original standard bucket is 12" wide. He is getting an 18" or 24" for occasional wide jobs.
    Frank
    [This message has been edited by PolskiFran (edited 02-02-2006).]
    The 41xx series pre-hard is only in the range of 30-35RC. Plain ole W-1 drill rod (as milled) is 35RC. You should be able to drill it easily.
    Apr 2005
    4340
    good enough for the wrist pins on an F111a swing wing fighter - should be able to handle a backhoe bucket in the cold.
