Results 1 to 7 of 7
Thread: Finding "rack threads"
    Talking Finding "rack threads"
    Hi Gang:
    I am in the process of building a homemade arbor press for my internal keyway broach set, and was wondering where I can locate the rack threads for it? Or maybe any other ideas for building a small press for my broaches?
    Thanks!
    NDAV8R
    Dec 2005
    Sequim, Wa.
    Try checking with your local bearing house. All the larger ones ( Kaman Bearing, Bearings Inc., etc) carry a line of gearing components.
    If that's no good do a search for Browning Gears I know they offer gear rack.
    I cut it twice, and it's still too short!
    Scott
    On the Oil Coast
    I tried to do what your attempting,buy a rack and building a press.It didn't work,not because of anything I did,it just turned out that I could buy a good used arbor press off Ebay including shipping for less than I could build one.
    If your determined to build one,then assuming you have a mill the best bet is to mill your own rack.
    Aug 2003
    North America
    What weirdscience said...Plus,
    Those things are made out of heavy cast iron for a reason. The frame is cast and designed to not flex under tons of pressure. Unless you can cast your own, or have a friend with a foundry, you're chasing your tail on this one.
    Arbo & Thor (The Junkyard Dog)
    Sep 2001
    Birmingham, AL
    www.mscdirect.com lists spur gears and racks in a variety of pitches and 4 or 6' lengths for the racks. Haven't looked, but would be surprised if MCMaster didn't have it as well.
    Steve
    [This message has been edited by sch (edited 02-13-2006).]
    Steve
    Sep 2001
    Birmingham, AL
    wrong edit button
    Steve
    Nov 2005
    geordieland
    Get steering rack from car breakers I saw homemade press a few years back, it seemed to work ok.
    MBB
