I have always had trouble with my lathe not cutting straight....I would get what I thought aligned correctly but it would always be out just that little bit...So I purchased a precision test bar...
It arrived today so I put it to use and sure enough my tailstock was out 0.04mm...I aligned it up very easilt with the tool and took a test cut....I measured a 5 micron deviation over 6 inches...woooo hoooo I was stoked...
The test bar has a 3Mt on one end and protected centers both ends and a nut near the 3Mt big end that you use to release it from a 3Mt socket, it is made in India....
Just got a 8" Starrett 98 on Ebay too....
