Results 1 to 10 of 14
Thread: .dwg to .jpg conversion
    Virginia, DC suburbs
    Another trick that I've used with nearly any WinBlows program (on Win2000 and WinXP, others may work):
    ctrl-alt-PrintScr will capture the image of the active window to the clipboard. Open Microsoft Paint and Edit-Paste the image into Paint. You can then save it as a ".bmp" file and convert it from there.
    Some programs override this somehow. For those, Alt-PrintScr will capture the entire screen to the clipboard, which can then be pasted into Paint.
    I know it's gross, and not precisely what you're trying to do, but I've done this in a pinch a number of times just so I could show what I was seeing to someone else.
    Science. If you don't understand it, don't talk to me about how it's going to end the world.
    Jan 2002
    Western, Kentucky
    I forgot about exporting the drawing as a .bmp file and then converting it to a .jpg. (Slaps self on forehead!!!) Thanks for the suggestions, guys.
    Greg
    "The truth is incontrovertible, malice may attack it, ignorance may deride it, but in the end; there it is." Winston Churchill
    Jan 2002
    Western, Kentucky
    Post .dwg to .jpg conversion
    I need to convert some Autocad drawings to .jpg format so they can be posted on a bbs as an image. Is there any good free software out there that will do this? Is there another way to post a .dwg without first converting it?
    Thanks,
    Greg
    tattoomike68 Guest
    I had to "save as" a .DFX then import that to paint shop pro, then export it as a .JPG
    thats the way I have to do it.
    Oct 2001
    Menu choices, File then Export will allow you to create a JPG directly from autocad.
    James Kilroy
    Mar 2006
    I do cad-cam modeling and I use a viewing software ( 3d VIEW ) I can print from there and I am pretty sure I can save as a JPEG file. Check out 3d VIEW on the web and see if you can download a trial program.How big a file do you have? I may be able to translate to you and send it back if you wish
    Mar 2004
    West Yorkshire UK
    You can save as a BMP file by using the BMPOUT command, then convert to JPG with any free file convertor.
    Phil
    PS There is a superb free file viewer called "e-drawings" which can be downloaded from the SolidWorks website
    Mar 2004
    West Yorkshire UK
    Phil
    Jan 2002
    Western, Kentucky
    Bump
    tattoomike68 Guest
    paintshop pro has a good screen capture feature , Im supprised photoshop does not have that!
