Results 1 to 4 of 4
Thread: making end mills
    May 2001
    Question making end mills
    I'm making a model gattling gun and need a .270" ball-end end mill which, of course, doesn't exist. Guess I have to make my own. Obviously it will have to be a straight flute cutter (no way to do a spiral) but I haven't been having much luck. Anyone out there ever had to do this? 'preciate the info.
    Portland Oregon
    Is .2756 close enough? That would be 7mm, and metric ball end mills are made. Also, it wouldn't cost a lot to have tool grinding shop resize a 5/16. Maybe you have a worn out one in your toolbox, that would be the ideal scenario.
    Jul 2001
    Id just use a .250 ballnose. If the Radius is just for clearance, or looks.Plus there Cheap!! Hey, When at Home, dont take them drawings sooo serious!!! But of course be accurate at work!!
    May 2001
    Lightbulb
    Someone in your area must sharpen end mills for a living.
    Find that kind of source and go through the sharpened endmills with a pair of micrometers & you should be able to find about any size you need.
    If not have them grind one exactly the size you want.
    If that does not work for you, I can provide that service for you.
