Results 1 to 8 of 8
Thread: newbie question--- scraping
    Jul 2001
    Post newbie question--- scraping
    In another post someone talked about hand scraping. Please teach me about this.
    Kind of tough to do in a forum like this.
    Here are a couple of useful links, though:
    http://www.machinerepair.com/
    http://www.csgnet.net/toolroom/scrape1.htm
    I've bough the book and video from the guy in the first link and found them to be pretty good, although I haven't had time to try it yet.
    Mike near Chicgo
    Mike Henry near Chicago
    Wink
    Not asking much, are we? Next you will want to know what makes women tick! Where does it end, Man! This is something you really learn by doing hands on.
    Go to the web site and order the book, read it, then take his course (if they are still on). The "Machinery Tool Reconditioning" book sold for around $100 in the back of HSMis a good resource as well.
    Maine
    "Machine Tool Reconditioning" is a good book, but pretty expensive if all you want to do is learn basic scraping technique. I think Lindsay Publications has done a reprint about scraping that's a lot cheaper and will give you the basic idea.
    Here's a summary, sort of:
    Grind the teeth off the end of an old flat file (one about 5/8" wide), back an inch or so, and grind the end to a slight convex radius, perpendicular up and down. Stone the end to a good finish, keeping square corners top and bottom. That's your scraping tool.
    Say you want to scrape a cast-iron angle plate. Get some Dykem Hi-Spot Blue or similar (a small tube will last you a LONG time). Take a tiny dab on your finger and rub it onto the surface of the angle plate you want to check, until there's a uniform very thin blue coating. Place that surface on your granite surface plate (or other flat reference surface), and slide it back and forth a couple of inches. Pick it up and look. You will see shiny spots where there was contact. Put the angle plate in a vise or similar, and with your scraping tool, scrape off the shiny spots. Rub the blue back over the scraped areas (you probably won't need to add more blue yet, just rub what's already on the surface back over the spots), and repeat the slide-on-the-surface-plate routine. Looks to see where the shiny spots are. Scrape 'em off. Repeat. And repeat. And repeat.... Eventually you'll be getting shiny spots all over the surface. Depending on how far you want to go, you can get more and more of them, closer and closer together. If you can get about 30 per square inch, over the entire surface, you have done very well and it's "enough."
    The process is very meditative. It also takes forever, and because it's so slow it's difficult to screw it up too badly before you notice.
    That's just doing a single flat plane. Things get more "interesting" when you want to get two surfaces perpendicular to each other, or scrape a dovetail way, or any of a number of other things. When things get "big," of course, you have to start bringing the reference surface to the work instead of the other way around, and sometimes you want to put the blue on the reference plate and look for blue spots on the work, and no end of other variations.
    The first time you do this, you will also discover that you have been made a member of the Royal Order of the Blue Finger, as that Dykem spotting blue will attach itself to your skin with a persistance that will astound you. Denatured alcohol cuts it as well as anything.
    [This message has been edited by SGW (edited 10-30-2001).]
    Jul 2001
    Thanks to all.
    My apologies to you; I messed up the request again. I meant to find out what scraping was, not to be "trained" to do it. But now that you have made an expert of me, I'll have to go into the business ;-) hee....hee...hee
    Thumbs up
    SGW,
    You can also use what the old timers used "Prussian Blue" in artists oil paints. One of the best solvents (for almost anything) available is d-limonene (citrus peel oil). It even removes crusty old Silicone Heat Sink Compounds. It is natural, safe to work with (but flamable-Safety first), and pretty cheap. Some of the "orange" handcleaners have enough of it to be quite effective. It will dissolve plastics (not all) so keep it from that stuff. It mixes with water as well - turns milky like suds.
    Scraping cast Iron Angle Plates...good practice! Cheaper than buying the precision ground ones for sure. Thanks for the idea!
    Dave
    Look into the on-line index, PM or HSM had some articles and a series or two on scraping within the last few years. I think the series was on a swivel vice. A quick low $$ way to have a look if you have the issues.
    Steve
    Oct 2001
    harry bloom in hsm ,middle 80s,......steve thomas later issues,90s
    best wishes
    docn8as
    docn8as
