Results 1 to 4 of 4
Thread: Gear cutting question
    Jul 2001
    Idaho Panhandle
    Post Gear cutting question
    Gentlemen;
    I am stuck (I think) in that I am not sure how deep to set the cutter into the gear blank. Mach. Handbook and other sources talk about “whole depth” but that seems to leave out “clearance”. Thirty-two DP gears figure from .0674 in. to .0708 in. for “whole depth” depending on my source. I have built a tailstock and mandrel for my rotary table so should be ready to cut metal soon. As per my last inquiry I plan a forty tooth and a one-hundred-twenty-seven tooth gear. The pinion to be brass and the spur to be aluminum. The aluminum should outlast me and be easier to cut!
    Jim
    Jan 2002
    Whole depth is the working depth plus clearance
    brent
    Nottingham, England
    Jim,
    Your first figure of 0.0674" is the correct one for the whole depth which, as Brent rightly says is the working depth , plus clearance.
    Usually if they are commercial cutters they have this information etched on them,
    Denotes as D+f=0.0674 where D is the working depth and f is the clearance.
    John S.
    we always took two cuts, even on gear shapers.
    Never can pick up and take the exact amount on the first part.
    good knashing
    kapullen
