Results 1 to 5 of 5
Thread: Change Gears
    Mar 2002
    Post Change Gears
    I would be grateful if someone could give me information on the change gears for a 1947 9inch South Ben lath. From the Boston Gear catalog it look like a 16 diametrical pitch. But the pitch diameter is not the same as in the catalog.
    Rich Stimpson
    3950 N. River Rd.
    Freeland, Mi. 48623
    Stimp1@worldnet.att.net
    Mar 2002
    Manitoba
    Rich
    I believe the dp is 18 (I have a '49 9")
    For your info - there's a southbend lathe group on yahoo www.groups.yahoo.com/group/southbendlathe/
    Lots of info there, particularly for the 9" models.
    Good Luck!
    Herb
    Maybe you're measuring the o.d?
    It will be two pitches larger than the pitch diameter.
    Example; A 16 tooth gear o.d. will measure the same dia as an 18 tooth gears pitch diameter.
    Just a thought.
    Hope you find what you're after.
    Ebay frequently has dealers "parting out machined piece by piece"
    Metal mite
    Oct 2001
    .. no. of teeth +2/pitch = o.d.
    p=no.teeth+2/o.d.
    best wishes
    docn8as
    docn8as
    the number of teeth + 2 ,divided by the pitch= the outside diameter of the gear blank
