We have an Enco lathe (110-2034) that sounds good until the tool gets to the work. Then there is a vibration in the headstock. The finish left on the work is rough as well. I can not feel any looseness or roughness is the bearings. After studying the print I still do not see how to get the spindle out. Any ideas on how to fix this problem would be a great help.
Thank you
john
