Keyway
How do you put an axial keyway on the inside surface of a 2"long by 1-1/2" diameter aluminum ring?
Thanks
A) With a keyway broach and bushing, in an arbor press or hydraulic press (or a big vise). Any tool supply place (Enco, Travers, Wholesale Tool, MSC, even Harbor Fright) can fix ya right up. Bring $$$.
B) With a shaper and a HSS lathe toolbit ground to the shape and dimensions you want.
C) By traversing a boring bar ground to the shape/dimensions you want back and forth through the bore while the part is held in the chuck of the(unpowered) lathe. Feed a thou or two with each pass.
D) By hand, with a file ground to width and given safe (non-cutting) faces on the sides.
There's probably other ways (hammer and chisel, anyone?
)but those seem the most practical.
Regards,
Walt
[This message has been edited by DancingBear (edited 05-02-2004).]
One more way that is simular to method "C" above is to use a boring bar in the milling machine and moving it up and down and moving the X or Y axis a few thou at a time. You might be able to get it done at a machine shop as it is a straight forward quick job(it depends on the shop).
Dancing Bear and coles-webb,
Such great straight forward solutions, mixed with, up and down, and back and forth.
Thanks a Heep.
Not the greatest picture, but it sure worked great. The only problem is that this is not the best thing for your spindle bearings since they are not spinning (whether on the lathe or the mill) so you probably shouldn't do this all the time. This picture was taken just a week or two ago. It got me out of a jam... hmmm. It seems I'm always trying to get myself out of a jam.
as per DB and CW
[This message has been edited by vinito (edited 05-02-2004).]
Vinito, Thank you much.....It surprises me that the force on the shaped insert is not to great. Oh I just realized, your still doing one thin cut per press!!
[This message has been edited by walkermaker (edited 05-03-2004).]
Why not make an aluminum plug to fit the ID, then drill a hole half in the plug and half in the ring?
If you can't use a round(ed) key, at least most of the material would be removed before you start the makeshift broaching operation.
Roger
Roger, Very Nice!
Winchmen's approach even works for making multiple spline sleeves. I've done a twelve spline sleeve by boring the holes in the pre-sleeve piece in a dividing head, boring out the center on the lathe, and then using a MinuteMan broach/bushing set with the half holes aligning the broach as I went around.
Herb
Herb, I just got a dividing head and find the idea stimulating. Where did you need a twelve spline sleeve...sounds like high forces? Thanks
No, on second thought, it sounds like big diameter.
- You may not post replies
- You may not edit your posts
Forum Rules
