Results 1 to 4 of 4
Thread: Lathe thread sizes
    Question Lathe thread sizes
    I have a couple of items that I acquired somewhere and would like to sell on ebay, but I need some information on which brand/ size lathes they will fit on:
    Faceplate with 1 1/4 - 12 threads.
    Headstock Jacobs chuck with 1" - 8 threads.
    Thanks for your help.
    Maine
    I think the 1" - 8 is more or less standard for wood lathes...not sure though, you ought to get independent confirmation.
    Feb 2005
    Lathe Model Spindle thread code Available for Supernova
    Record, Coronet, (except red paint Major) Carba-Tec ¾" x 16 TPI MC1 yes *
    Axminster M330/600/900/950/Perform, Delta 1" x 8 TPI MC4 yes *
    Draper, Nu-Tool, Clarke, Naerok, Rexxon, Seally, Hilka and other importers of far-Eastern lathes use either ¾" x 16 or 1" x 8 TPI and you need to check which it is ¾" x 16 or 1" x 8 TPI MC4/MC1 yes *
    Hegner, Woodfast, some Sorby, Killinger, Wabeco, Hapfo, Hager, Flott, Konig, Emco, Sheppach and most German lathes use this thread but please note the register size varies and specials may be required. 33mm x 3.5mm MC22 Special - please enquire
    Harrison Graduate, Apollo Professional, most Poolewood, Axminster Superlathe 1½" x 6 Whit td>MC2 Special - please enquire
    Apollo (except professional), some Sorby, Astra, Tyme Avon, Selbix 25mm x 2mm MC30 yes *
    Harrison Jubilee, Arundel E5 1" x 10 BSF MC12 yes *
    Al-ko HDM 850 30mm x 1.5mm MC34 no
    Arundel K450/K600/M230, Luna 24mm x 3mm MC21 Special
    order
    Clarke (pressed steel bed) ¾" x 10 TPI MC10 yes *
    Coronet Major(Red)pre 1977 7/8" x 16 Whit MC8 special *
    Electra Beckum HDM800/1000 20mm x 1.5mm MC39 yes *
    Elu DB180 18mm special MC27 no
    Nova, General 260 1¼" x 8 UNC MC23 yes
    James Inns (Sherwood) ¾" x 10 Whit MC10 yes *
    Multico 20mm x 1.5mm MC39 yes *
    Multico Supershop 5/8"Plain shaft MC5M no
    Myford ML8, Turnstyler 1" x 12 Whit MC3 yes *
    Myford Mystro 11/8" x 12 Whit MC20 yes *
    Shopsmith 5/8"Plain shaft MC5 no
    Sorby lathe (old models) 25mm x 2mm MC30 yes *
    Tyme Cub/Gem 20mm x 2mm MC29 yes *
    Viceroy (Denford) 1½" x 8 TPI MC6 no
    Old Vicmarc, Nova 30mm x 3.5mm MC13 special
    Left Hand Threads
    Harrison Graduate/Woodfast 11/2" x 6 Whit MC2B Special - please enquire
    Myford ML8 7/8" x 12 Whit MC3B yes
    Rockwell Delta 1" x 8 TPI MC4B no
    Harrison Jubilee 1" x 10 BSF. MC12B yes
    Naerok/NuTool 3/4" x 16 UNF MC40B no
    Barry Milton
    David,
    When listing the Jacobs headstock chuck, make sure to mention "fits 6" Atlas Craftsman lathe" in the title, you'll get maximum exposure & a high final bid.
    (Don't forget to have the word lathe in the title)
    Ed
    Ed Pacenka
