Bridgeport power feed
I have a used Bridgeport,variable speed milling machine.The wires to the power feed have been cut just outside of the drive motor.The colors are
ink,gray black,white,orange,dark green,red,light green brown,blue,yellow,purple.Does anyone have some info on how to wire this thing so that the power feed can be used.The model number on the machine is:1560AA as near as I can tell.Thank you one and all for any info you can supply.I just retired after 43 years in the Merchant Marine,serving with Military Sealift Command and am trying to get this small shop going.Thanks again.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
