Results 1 to 9 of 9
Thread: homemade metal brake plans?
    cobrafd Guest
    Default homemade metal brake plans?
    Was wondering if anyone out there has a good set of plans to make a metal brake?
    Maine
    Dave Gingery did plans for a sheetmetal brake. It should be available from http://www.lindsaybks.com/
    Sep 2004
    Oregon Coast
    Smile Break drawings
    There is a set of good looking drawings of a sheet metal break, looks to be about 24" on this site:
    http://www.homemetalshopclub.org/projects/project.html
    They are zipped but you can download, unzip them and save them to a file and print them.
    have fun
    Mel
    Nov 2005
    Very nice one shown here:
    http://www.homeshopmachinist.net/bbs...ad.php?t=15478
    It's from the book "Metalworking, volume 2". That's a good edition, BTW, I bought the book for the brake plans, but there are a number of other nifty projects there as well.
    Best,
    BW
    Aug 2003
    Default Sheet Metal Brake
    Lugnut
    The Zipped drawings for a Sheet Metal Brake listed in the Home Metal Shop Club page were made from a unit I designed and built. It is a 24" capacity unit and the only modification I would make is to cut a few slots or split the top member to make it a pan brake. It is a very heavy unit and works very well.
    JRW
    Sep 2004
    Oregon Coast
    Smile Jrw
    JRW it's a small world! I would like to build it but I just don't room for one now. I looks like a great project. I filed the plans away just in case I get the time and room.
    Thanks for putting them out for us to see and use.
    Mel
    Default Bending brakes....
    OK so what kind of brakes;
    As stated, JRW has some plans for a very nice design. Could be modified to be a box & pan brake as needed.
    I've found other plans on-line for a type of hydraulic press-brake.
    I self-designed an 8 ft. brake based on a conventional Chicago brake I've used before. My design seems to make ductwork OK...
    Still sometimes use the Chicom press brake. Works OK for light stuff.
    Jan 2002
    Toronto, Ontario
    Default Metal Brake
    Feb 2005
    gettysburg pa.
    i have the gingery book #7 desiging&building the sheet metal brake.
    from lindsay publications.
