Results 1 to 10 of 10
Thread: extension to shaper table
    Default extension to shaper table
    I have two spin indexer's one I am converting actually fitting to a table not converting so that angles can be adjusted i.e raised and lowered for mill cutters to be sharpened with the aid thanks to our pal sir John of a crosslide vice so that I can get lateral movement.The other I had always anticipated fitted as I once saw done to an extension at the front of my shaper table.This would be facing forward so that I can cut some gears or splines spline gears on this as opposed to the milling machine. Has anyone built an extension such as this to their shaper???kindest regards Alistair
    IOWOLF Guest
    Are the other two post like this one?
    Nottingham, England
    Yes,
    Alistair has three shapers
    John would I be in this shape if I had three shapers Alistair just clumsy fingers sorry guys
    IOWOLF Guest
    If it was up to me, You would be forgiven, Scottie.
    Thanks Pal Alistair
    Mar 2003
    it all depends on what you can scrouge up,a piece of lathe bed,a thick chunk of steel?
    what also might work would be to find a piece of heavy plate ,cut out your attachment and mount it to the side of the shaper box, the deep section would add more rigidity
    Thanks would a good solid non webbed ,slotted angle plate do for this? It seems the obvious solution ,and I have one large enough.Alistair
    Sep 2004
    Default Extension For Shaper
    I built one two inches thick by 10 inches wide and 24 inches long. I actually just finished grinding it flat and will throw it on the cnc for the key down the middle. I have it for a 14 inch elliot shaper. Should be stiff enough sure is heavy round 120 pounds. Found the chunk of steel in the ah garbage can at work. Lucky me.
    Nottingham, England
    Alistair,
    Have a look round and see if you can't find a small box table and bolt this to your shaper table to extend it.
    Here's a pic of what I mean fitted to this drill.
