Results 1 to 7 of 7
Thread: Using toolpost to set lathe tool angle to workpiece
    Jan 2006
    Question Using toolpost to set lathe tool angle to workpiece
    I need some explanions on angle etc to use in presenting various preformed lathe tools to the workpiece for different types of cuts. How much of the tool should come in contact with the workpiece and how does that all effect the speed, feed, depth of cut and finish? I read the section of the Machinists Handbook that covers this but it was too complex for me to understand. Beginner, any explanations or website directions would be most appreciated. Thanks! Bero
    Beaumont, TX
    There are two principle angles that govern the ability of a lathe tool to cut: top rake and front/side clearance.
    First the clearance angle: Imagine a cross section of the cut as viewed horizontally, from the side. The drawing below was to illustrate the clearance angle of a drill, but the same idea applies to a lathe tool if you just turn the drawing 90 degrees clockwise and imagine the work moving instead of the tool.
    The top image shows what happens when there is no clearance. The flat face of the tool just slides over the work, like a bearing. It would make very little penetration and would not produce any chip.
    The second image shows that when a clearance angle is formed on that face of the tool, it can now penetrate as it can slide down the ramp that that angle cuts in the work piece. I did not draw a chip but it would be there.
    The clearance angle is measured from the original flat surface to the actual angle as shown. Clearance angles are commonly between 5 and 15 degrees. The larger the clearance angle, the faster the tool can penetrate into the work. But it also becomes weaker as the clearance angle is increased because there is less metal under the edge.
    The clearance angle of a lathe tool is on the front and/or side faces.
    The rake angle is the next to consider. This is the angle of the top of a lathe tool or the left side of the tool shown in the drawing. It is the surface that the chip slides over as it is cut. The tool in the drawing has a 0 degree rake angle: that is, it's cutting surface is perpendicular to the work. As the top of the tool is ground to have a smaller angle as seen in the above section view, it is said to have a POSITIVE rake angle. If the top were ground to product a larger angle in cross section, then it would have a NEGATIVE rake. As I said, the tool in the drawing has a 0 degree rake. A positive rake angle would cause the tool to try to dig into the work, while a negative rake would try to force it out of the work. Thus negative rake tools require more force or pressure to keep them cutting.
    Clearance is necessary for almost all tools. That includes drills, lathe tools, milling cutters, wood saws, etc.
    The rake angle is a more complex subject and often must be determined by experiment. I always start cutting aluminum and steel with a positive rake tool. But this is only a starting poing and I am not the most experience one here on this question. Brass likes a 0 or negative rake to prevent the tool from digging in too fast which can cause tool breakage and vibrations that leave a wavy surface. I use a Dremel to put a 0 degree rake angle on drills for brass.
    If you need a starting poing, then the various handbooks and other references will show suggested tool shapes and angles for various materials.
    As both the clearance and rake angles are made more positive, the included angle of the tool at the cutting edge becomes smaller and the tool will become dull faster.
    Those are the most important angles. The tool will also have an angle as viewed from the top. Most tools will have a front face and a side and the angle between them will vary for different purposes. My most used tools have about an 80 to 85 degree horizontal angle between these faces and I grind relief on both of these faces to allow cutting on either or both of them. This is handy when turning a diameter up to a shoulder. On the final cut, I cut right to left up to the shoulder and then back the tool out to finish that shoulder. Other angles are used. A threading tool would have a 60 degree horizontal angle to match the Vee of the threads. And other shapes are possible. Cutoff tools have a square shape. Whenever possible, the sharp point formed by this horizontal angle should be rounded to a small radius to prevent it from becoming dull too quickly. Roughing tools should definitely have a radius here. A finishing tool can be left sharp is needed.
    Surface finish is another complex subject. There are some suggestions but again you may have to experiment. I have read that a large radius between the front and side faces helps to produce a better finish. This may be true for some materials but not for others. The first three things I would insure for a better surface would be rigidity. Any vibration in the tool or work will show up in the finish. The second thing is sharp tools - SHARP, SHARP, SHARP. I use a quick change toolpost that allows the tool to be removed and restored to the same position. This allows it to be touched up while the work is in progress. The third thing is a good cutting fluid. It is amazing how much this can help.
    Only after these three things are absolutely insured, would I look at changing the tool geometry.
    I know this was a bit long, but I hope it helps.
    Jan 2006
    Default Thanks for very helpful reply to my ?
    Hi Paul,
    Your reply covering lathe tool angles etc. was very helpful and most appreciated, Regards, Berol
    Jun 2006
    Ladys Island SC
    Thank you for that post... in the process of setting up my own lathe, and this question/answer is now in my bookmarks.
    Thanks
    Toledo, Ohio
    Paul's explanation is very good, and will be a great help in grinding and applying cutting tools.
    I would also recommend any beginning machinist to get a copy of the Atlas Manual of Lathe Operation and Machinists Tables. It is probably the best source of information for lathe operation.
    There are many more books available with more information, but the Atlas book will explain the basics and make much of what is in the others understandable.
    Default wdtom
    When Paul said sharp, sharp, sharp, he might have also said to stone the tool after grinding. Use ever finer stones until it is mirror smooth for best results, worth the time.
    Beaumont, TX
    Also good to stone them from time to time when they are in use. With a QC tool holder, this can often be done without disturbing the setup.
    One thing I have been doing lately is using a belt sander instead of the grinder to sharpen the tools. I bought a 1" belt sander from Grizziy for $40 or $45 on sale. I find it is easier to set the angles on the sander's table and the flat belt makes it easier to get the shape you want. A fine belt with a bit of Tap Magic on it (use a brush to apply it while the belt is moving) will produce a near mirror finish and will save some time with the final stoning. I do still use the coarse wheel on the grinder to originally shape the tools as it cuts faster than the belt.
