Results 1 to 10 of 17
Thread: Attention: Golf Ball Pro's
    Question Attention: Golf Ball Pro's
    In the current MW issue(8/9-06) under TIPS & TRICKS the author of "GOLF BALL HANDLES" states his " only tip is to make sure the golf balls are not liquid filled."
    Does anyone know how I could tell if a golf ball is liquid filled(prior to drilling), what is the liquid filling, is it hazardous, and what precautions should be taken? Thanks Paul
    Kiwiland
    Not poisonous. The hazard is that if not carefull you and the workshop will be covered in it. As for precuations, wear a rain coat! More seriously try a small test hole ( I used a batttery portable drill over the sink) without holding the golf ball in a vise or at least not tightly so as to not to compress the liquid inside. It will still squirt out a little so be prepared.
    Murphy was an optimist
    Cheyenne Wyo
    Top Flites are solid. Easily obtained. Don't use Titleists, they are wound. Those are two real common brands. Skin on a wound ball is approx. 1/16" thick, so you'll know pretty soon if you're into brown rubber bands. Rubber bands don't drill so good either. Solid balls can be most any color inside, but I don't recall ever seeing brown. It'll drill cleanly. You should be good to go now!
    IOWOLF Guest
    Author here, most modern G-balls are ok,as a matter of fact I have never seen a liquid filled ball.
    But someone has I suppose,therefore the warning.
    Sep 2002
    dsm, ia
    Most of todays balls are solid core. The older "wound" balls are getting pretty rare.
    Here are some balls to watch for liquid centers; Titleist Tour Balata, Titleist Professional, or Hogan 428 Balata. These are older, and you probably won't see too many.
    Jun 2005
    Almost Dallas
    I don't know what the liquid is in the core of some golf balls, but my 40 year old memory of unwinding a couple is that the stuff smells horrible.
    Millman Guest
    Default What???
    It does smell. Why would you ask for opinions on drilling a golf ball? If the thought scares you that bad;;;don't do it,,,leave it to us professionals to drill the hole for you.. Send me the ball;; I will send a hand-written report for 200.00 USA. Can't believe people are still afraid of their own golfballs and their skills?????
    Jun 2004
    My Labrador used to love the wound balls. He'd get the cover off, then give the windings a crunch and hold his nose down to the ball and wait for the windings to "pop" and sting his nose. Then he'd do it again.
    Lynn S.
    IOWOLF Guest
    Dogs are stupid that way,A cat would get snaped and hide for an hour,then do it again.
    Aug 2004
    Northeast Ohio
    Default Golf balls
    I drill golf balls all the time, I use them for file handles. They fit my hand and keep the tang from stabbing me. It also gives me something to do with all the golf balls I wear out.
    Paul in NE Ohio
