OK guys it is my time to have a reality check. I've found yet another area of machining that I am woefully underspeed.
I know many of you have built small engines from castings. I took the leap and found right away that working to a set of plans is far and away different than just cutting and fitting. Any way, the castings came and I have been poring over the drawings and here is where it began to dawn on me that I was a tad behind the curve.
I need to know how a machinist (can't include myself in that) determines where to start on a rough casting. It appears that a reference point to refer to is mandatory as a place to begin the layout of vitually all other points that are to be machined. Is that true for each plane to be machined? (hor./vert.) It follows that if you don't get the first one right then all the rest are junk as well.If I add to that the differences in each casting then I am even more lost.
This may seem simple but it seems to me that ALL the machining processes must be determined before making any chips.
Tell me gurus of the lathe.......
Thanks
Caddy
