Results 1 to 6 of 6
Thread: E-clip Sizing
    Jan 2002
    Huntsville Ala
    Default E-clip Sizing
    What does the size of e-clips describe?
    If I have a 5/32" e-clip, is that telling me that I need to cut the groove bottom to be 5/32 in dia for the proper fit?
    May 2004
    New Jersey
    Default Retaining clips
    Lynn: clip size = shaft size a 5/32 (.156) clip needs a .116 inch diameter groove. Re pg 1613 Table 14 Machineries hand book 25th Edition.
    Hope this helps
    Tin
    Taftville CT
    Default Shaft Diameter
    If you have a 5/32" e-clip, (external retaining ring) it is for a 5/32" diameter shaft. The groove for a 5/32" e-clip will be .116" dia. x.029" wide max bottom radii .005". Machinery's Handbook has the dimensions for depth, width, and margin for external retaining rings. That's where I got the above information.
    BTW, if you were not aware, there is more than one style of external retaining ring slanged as "e-clips". Of the two e-clip styles, one will take more of a static thrust load # than the other.
    I see I was beaten to the answer while typing this.
    Scotland.
    Have a look at www.rotorclip.com
    Mark.
    Jan 2002
    Huntsville Ala
    Thanks folks.
    I didn't have a handbook available. ...nor did I find a website that addressed that. Matter of fact I don't see that on rotor clip's site either. I see their formula for 'end margin', but not depth.
    Again, thanks.
    Lynn
    Lynn, this is the clip information from the rotor clip website. Warning it a 9 mb Adobe file.
    John
