Hey gang, anyone ever try to cut gears that were not in the recommended range stamped on the cutter. My cutter is for 26 to 34 teeth and I need to cut a gear that is 21 teeth and one that is 42 teeth. I know that I can buy the correct cutter if I have to. This application is for hand cranking and not high speed.
Any thoughts or experiences will be appreciated.
TIA.
Bob
