An urgent (as in DOD contract) need has arisen to make several hundred assemblies of 6" aluminum channel, which will entail lots of bevel cuts crosswise. Bandsawing won't work. This channel is 5/16 thk accross the bottom, with 2" walls that taper from about 5/8 to 3/16 (radiused inside corners).
Would this be doable on either a tablesaw, or radial arm saw (by feeding the radial saw carriage back into the cut to avoid climbing)? (Wearing out the equipt. is not an issue here.)
Or does anyone have any other suggestions?
