I just had an idea (AKA Brain Flatulence).
What if one were to start with a VFD for 1ph to 3ph. Then use that to power an RPC idler (technically not an RPC in this scenario, but follow along...). This then would be hooked to mill, lathe, whatever.
Thoughts:
1) This would eliminate any need for start caps or run cap phase balancing.
2) Would this allow you to use the normal drum switches and contactors to control the machines? In other words, would the idler motor shield the RPC from the damaging effects? What about instant reverse? Hmmm, I think not...
3) You could still control speed using the VFD, though obviously it would affect all motors. But in a home shop, where you’re only using one at a time (typically), who cares.
Not economically ideal, but if #2 above works out, this could be a rather nice combination and perhaps an easy/cheap improvement for VFD owners. But, alas, I'm sure someone will confirm that the idler will not be sufficient to buffer the VFD against the eddy cause by switching down stream, much less instant reversing.
