Originally Posted by
Carld
There seems to be a lot of detail missing.
Cantilever means the axle is stationary (welded or anchored to the frame). The flange is to hold the caliper I assume since the rotor would be secured to the wheel hub. The flange could serve as the stop for the bearing if there is a small dia. extending out for a seal wear area and as a stop for the inner bearing race.
I don't have a clue as to where the 75 ft lbs of torque enters the picture, unless that is what you intend to torque the bearings to which would be about 74 ft lbs to much.
I would suggest 1045 cold roll as it can be welded and heat treated. It does get brittle when welded as I understand it and has to be annealed after welding. Tool steel would not be a good choice.
As Lew said, it's a quadracycle, not a bicycle.
If independent wheels, how do you propose to drive each wheel?
