Originally Posted by
pepe
at one time harig coated the ways of cable driven 6-12's and 6-18's with teflon. imho not a great idea. if your machine came from a shop that permitted air hoses around the grinders you may have a problem. on removal of the table you should be able to see if this machine had a teflon coating. the far ends of the table ways, that seldom get fully traversed, should still have the remenants of the coating. the middle of he table ways may be scored if abrasive grit was blown in to mix with the way lube;these ways were not hardened as they are on some other models. if this is in fact the case, putting way lube on these surfaces may not help much. when you have the cable off, check to see if the longitudinal hand wheel spins freely. lubing this shft and its bearing may help.
good luck p.
