Originally Posted by
Rich Carlstedt
I would think your concern would be valid with the "old"
Tap Magic..for ferrous materials.. they would caution you
to use the Aluminum only version..as The Ferrous stuff, desolved Aluminum
(Boy I wish had some ..when you got a stuck tap, you poured
it around the tap, and it ate up the chips in a hurry)
Then in 1980 or so then deadened the Ferrous stuff and it no longer
attacked AL, but they still want you to use AL only fluid.
I have never heard of a problem as you mentioned !
However I have heard that mixing iron dust and Aluminum
is a concern ??
Rich
