Results 1 to 7 of 7
Thread: Mini V Belt source needed
    May 2001
    Colorado
    Default Mini V Belt source needed
    I have a Dyna benchtop CNC mill. It uses a Polimax 5M530 v belt. Anybody know a source to buy one (other than the Dyna manufacturer)?
    Thanks,
    Jim
    Maine
    You might look at www.mcmaster.com and see if they have it. If not, they might be able to get it.
    Jun 2006
    Austin, Texas
    Check your Yellow Pages for the local bearing supply shop -- they carry most of the V-Belts in stock.
    If you don't have a local bearing supply, Motion Industries will carry it:
    https://www.motionindustries.com/mot...p/mi/index.jsp
    May 2001
    Colorado
    I checked with Motion Ind and they have a Gates equivalent.
    Thanks,
    Jim
    Jun 2006
    Austin, Texas
    Motion Industries carries the Gates brand as well. I really like the Gates PolyFlex belts. I replaced the crap belts on my RF-30 Mill/Drill with the cogged PolyFlex belts, and it really made a huge difference in reducing vibration.
    I also upgraded the belts on my Clausing lathe from the stock Browning Belts to the Gates PowerFlex belts.
    "Polyflex® JB™ and Polyflex® V Belt Drives
    Gates Polyflex belts are designed for high performance at high speeds. Both are ideal for shorter centers, smaller-diameter sheaves and larger ratios. They are precisely manufactured to provide less vibration and run smoother on high-precision applications like machine tools and computer accessories. The belts also resist flex fatigue, heat, abrasion, ozone and other tough environmental conditions. "
    Nov 2004
    Kingsport, TN
    http://www.ebatmus.com/
    I ordered a small belt for my mini lathe from this company and had good service. Your mileage may vary though. Good luck.
    Jonathan P.
    Mar 2006
    Another vote for www.ebatmus.com . They are fast with shipping and have good prices. I have ordered many Gates polyflex V belts from them.
    Steve
