Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: OT: computer turns off by itself.
    It is kind of strange. When it shuts down, xp closes any open windows and then logs off and shuts down. Not like you would expect if the power just failed. I just got a flash drive with Linux on it that I can boot it up with. I was going to try that just for fun.
    Phoenix, AZ
    Oh, well that's another animal entirely. You can program a "soft off" for the power switch such that a momentary press tells windows to shut down. So a contact in the switch momentarily shorting could trigger that. Likewise, when off, a momentary short could trigger the power on. It's not really an on/off switch, but rather just a trigger that is software latched in the mobo. Starting to sound more like the switch...
    I tend to agree with BadDog on this one. I had forgotten about the soft shutdown that can be triggered by the power switch. His diagnosis makes a lot of sense.
    If you change the action that happens when you push the power button (it's a setting under the "Power Options" control pannel), see if that action happens instead of the computer shutting down automatically. I recommend the "Ask me what to do" option. If that window pops up randomly, instead of the computer shutting down, then you've really isolated the problem.
    52N 122W Western Kanuckistan
    If you have a reset button just move that wire to the power on connector position and try it for a while.
    It ran fine for a couple of hours last night and several today. After this morning I swapped the reset switch for the power switch and will see what it does.
