Originally Posted by
Terry
If you want a pair of glasses that you will not take off until you go to bed,
buy a pair of quadrafocals. It has top and bottom bifocals, strenth adjustable between the two. I had my top ones made stronger than the bottoms for reading motor plates laying under a machine. The next lens above the bottom bifocal is to see two to three feet. The middle lens are either clear for distance or set just for your vision problems.
I have been wearing these for about fifteen years. Love them. I can stand back from a lathe or mill using the two to three feet lens and watch the tool cutting without getting hot chips or read a newpaper laying flat on the table without moving my head at all.
The only problem is 360.00 dollars plus every five years, but worth every penny. You just won't believe how nice it is to wear glasses that work.
