Results 1 to 10 of 10
Thread: Need Tooling Help????
Hybrid View
    Sep 2004
    Default Need Tooling Help????
    Im gonna be doing a 304 Stainless Machining Job. Im kind off intimidated by this stainless material, I did some research on internet and everyone has just bad things to say about it. I need to turn outside diameters of 5 inch to 4 inch .682
    o/d. Also drill bore to 3 inch inside diameter. I wonder how the heck to do this with what type of special cutters??? Is coated carbide required?? Also have some tubeing 5.563 outside diameter that also has a 5.293 inside diameter. (schedule 10 5 inch Pipe) It needs 1.330 diameter holes produced radially every 90 degrees. I am purchasing building a coolant pump system. I am just worried that my equipment and current tooling may not cut it. What type of cutting tools do you suggest i use?? Thanx Mike
    Apr 2001
    Clinton, WA
    Mike,
    What kinds of machines do you have for this job? What types of tool holders for the lathe. There are a lot of new lathe insert styles and coatings that work well on stainless but usually require high HP and rigidity, I would need to know what you have to work with to make an accurate recommendation. For drilling Cobalt drills work OK in that material, best if you can use coolant. Stainless work hardens very easy so you have to hit it fairly hard and fast which is why you need high HP and rigidity.
    Mark Hockett
    As Mark already said, work hardening is a big issue with 304 stainless.
    At work we hit it hard and flood the coolant.
    At home I don't have coolant so I take take an opposite approach. I use
    positive rake inserts and tools to reduce tool pressure. 304 is not free cutting
    at it's best, but doing what you can to reduce the stress of the cut will
    reduce the work hardening.
    I HATE 304 stainless!
    Sep 2004
    Default Stainless machinery Available
    Bridgeport Mill ing machine and a cincinatti toolroom traytop ;athe. Quick change tooling on lathe r8 collet system on mill.
    Aug 2002
    I'm no expert, but I spent several long weeks last summer machining a lot of 304. It can be a real pain, as you have read, but there are a few things that may help...
    A lot of bars that are sold as 304 are actually 304L. I believe that this variation of 304 includes additional Lead which reduces the extent to which it work hardens (much like 1214 Steel versus 12L14). It's still not 'free machining' but it's a lot better. Infact, I don't mind turning 304L.
    In addition to work hardening like crazy, 304 has a lot of carbides included in the metallic structure, meaning that it is very abrasive. I have worn through TiN-coated carbide cutters very quickly because of the abrasive nature. Addressing both of these problems requires aggressive cuts that remove the previously work-hardened area on each successive cut. I used very beefy negative-rake tooling to rough the parts to size, and finished with a normal brazed-carbide tool (which I had to constantly re-sharpen). As a side note: I was using a Clausing Colchester 15 lathe with a CXA toolpost. The BXA toolpost on a smaller lathe couldn't withstand the forces caused by the negative-rake tooling.
    Unfortunately, I cannot address the 3"-ID boring operation. I had to repeatedly perform a similar operation... each of which killed one corner of a triangle-insert boring bar. I did not use coolant as it was not available for that machine. Perhaps a coolant bath would extend the tool life.
    Correction: Thanks to Peter Neill, the L refers to a "low-carbon content." My mistake, but thus why I prefaced it with "I believe..."
    Jan 2006
    Suffolk, England
    Btu44, the "L" means that it is a low-carbon content grade of stainless.
    There is no lead added to stainless steel grades.
    Peter
