Results 1 to 10 of 13
Thread: Bearing fit
    Question Bearing fit
    If you make a spindle/axle for a bearing how tight should the fit be? Slide on our press fit? Say a 5/8 dia.
    Feb 2005
    About .0001" to .0004" interference, depending on bearing design, journal surface finish, load, speed, lube, service factor.
    Oct 2004
    WA Western Australia
    what kind of bearing?
    Just got my head together
    now my body's falling apart
    Vancouver's Island
    As well as expected service temperature range and the phase of the moon when installed.
    Oct 2004
    Wink
    Moon phase is only relevant to phos bronze!
    Default Bearing fit
    This would be for a wheel bearing light duty use.
    Oct 2004
    "wheel bearing light duty use"
    sorry Tim, you're gonna have to a lot more explicit if you want a meaningful answer.
    "light duty" for a garden wheelbarrow or
    "light duty" for an occasional run at Bonneville on a 1920 Indian Scout?
    Pardon me if I sound facetious, I've heard sillier questions asked by engineers.
    tattoomike68 Guest
    Quote Originally Posted by timh
    It its on a haul wagon that you pull behind a tractor then .001 clearance slide fit is fine. you wont need a hammer and chisle to change the bearing if it ever needs it.
    It may be a bit tighter if its on a boat trailer that goes down the road at 65 MPH.
    Jul 2001
    Green Bay, WI
    If the spindle is stationary, as in an automobile front wheel bearing, The spindle should be loose sliding fit, and the OD should be a press fit.
    If the spindle turns, then it is opposite, with the spindle being a press fit, and the OD a sliding fit.
    Rich
    "Loose" is .0005 clearance
    "Press" is .0003 interferance
    Jun 2003
    Default More strictly speaking . . .
    The bearing race that rotates relative to the load should be tightly fitted, the bearing race that is stationary relative to the load should be slip-fitted.
