I have just purchased a sensitive 0-1/4 drilling machine with no makers name, but looks to be good quality and fairly old. The spindle runs in split for adjustment cast iron bearings. The pulley arrangement, which looks original will give speeds up to 4000 rpm, would like to know if this type of bearing is ok to run at this speed ? The spindle is unhardened and appears unworn. David
