I am in the process of making bore guides for rifle cleaning .. I am using Delrin Rod.. but am having an aweful time drilling
the hole thru the center .. I'm just using
a regular drill bit , 12" long, with most of the shank turned down ..
Is there a drill bit more better suited for the task and what should I use for a lube ??\
Thanks in advance
Randy
