5 inch chuck on my 7 x 10 lathe
This bigger chuck does let me do many more things. But it also shows me that if I want to do bigger things, it's time to look at buying a bigger lathe.
The article/posting at:
http://www.mini-lathe.com/Mini_lathe...ck_5x3/5x3.htm
I didn't do the mounting like the posting said, I used a face plate that I purchased when I got the lathe. I just laid out the pattern on the face plate and drill the hole accordingly.
Works great and adds a new dimension to this little lathe.
Jerry
- You may not post replies
- You may not edit your posts
Forum Rules
