Results 1 to 9 of 9
Thread: How Do I Do This?
    Apr 2006
    Chicago Area
    Default How Do I Do This?
    I could use some advice from folks with more experience than I have.
    I have sawed off the top of a propane tank (picture a metal cup about a foot in diameter and a foot high), and now I want to clean up the sawed edge.
    As you might expect, the rim of this "cup" is pretty limber, even with the base firmly clamped to the table of the milling machine. It tends to shimmy and ring when the cutter bites in (scary AND deafening). Regular side-cutting end mills do NOT seem to be the tool for this job. A slitting saw does somewhat better, but it still doesn't seem to be what the job calls for.
    I've tried clamping mass to the rim and cross-bracing the open end of the cup without much noticeable improvement in the situation. I've thought about filling the thing with sand to try and damp out some of the vibration.
    Any ideas on how to approach this job? Thanks in advance.
    May 2005
    Milwaukee
    Angle grinder/sander and a sharp file....
    Jan 2002
    Huntsville Ala
    I'd opt for the file. Quieter and more peaceful, and therapeutic to boot.
    Jul 2004
    Tarkio,Mo.
    How about sawing a hole in some plywood slightly smaller than the tank. Sand the hole until you can force it on tank. This should make the wall of tank rigid enough to use a hand grinder.
    Gary Davison
    I had a friend do exactly this with angle grinder with grinding disc then angle grinder fitted with flap discs.Alistair
    Feb 2005
    Don't know what your tolerance or final application is, but the angle grinder will work with a sanding disk, or if you need greater accuracy the sand will work.
    Oct 2004
    Prestatyn, North-Wales
    fill the thing full of wet sand
    all the best..mark
    Apr 2006
    Chicago Area
    Default The Sand Did the Trick
    For the benefit of anyone else who tackles this same problem, packing the thing with sand really did the trick! The job ran so smoothly and quietly that you would have thought I knew what I was doing :-)
    Thanks to all who replied. I'm sure the grinder would have worked too if I were less retentive (my problem, not yours).
    Thanks again.
    Dec 2005
    Aboard said the same thing I was going to say.. Dampen it with sand mass.
    Excuse me, I farted.
