Results 1 to 2 of 2
Thread: Belt Grinder
    daedong Guest
    Default Belt Grinder
    Hi, my name is Vin and this is my first post. I have only recently bought a mini lathe and have no experience what so ever with machining.
    I have started to make some components for a belt grinder, I have cast an idler and drive wheel over the last couple of days. I have machined and fitted bearings to the idler.Tonight I machined the drive wheel to shape. I need to bore the centre out for the shaft (3/4") how should i do this? I do intend to put a keyway in the shaft and pulley but not sure how to then retain the pulley.
    tattoomike68 Guest
    You will need to drill and bore the drive and pully. so you will need a 1/2" boring bar. If you have a machine reamer you can drill it 23/32" and ream it if you have a reamer.
    many times to hold a drive roller and a drive pully to a shaft they are keyed and have set screws over the keys and at 90 degrees there would be a second set screw. so you might want to have a good size hub a little longer and bigger around for the drive side.
