ViaCAD info needed.
I've downloaded the free 14 day version of ViaCAD and must confess to having more luck with it than any other cad program. I am still having some problems and the tutorials done at break-neck speed are very little help to me although I've watched them a hundred times. He moves the cursor so quickly I can't get a eye on where he's going. Also, the scripted tut's are extremely basic. As an example, he doesn't mention which tools are only used in the trimetric mode AND, which ones require you "select" before or after choosing the tool.
But I can see where this program will work for me but I could sure use a little help. Does anyone know if you buy the program box at the store, does it include tutorials? I've had the box in my hand and read the entire thing it makes no mention of what's in it. It's heave, likely has a book but my guess is probably the same information they give you in the scripted tuts'. Are there tutorials available for it? I've searched Borders and there are no books available yet that I can find.
Also, Sir John, you were going to look at this you mentioned. Do you think it will work for a backyard cnc setup doing fairly basic 2d parts?
