Results 1 to 4 of 4
Thread: Sino Sds2-2m Dro
    Mar 2006
    Hartsville, South Carolina
    Default Sino Sds2-2m Dro
    I have a Sino SDS2-2M Digital Readout on my Bridgeport Mill and i am trying to do "PCD Circle Equally Dividing ". Are there other members here that have this DRO that might help me with this, and i do have the book that came with it. I cant understand how to use the DRO right. Thanks
    The whole is greater then the sum of the parts.
    Apr 2002
    Central Iowa
    Smile
    Quote Originally Posted by Backyard
    Had one, but sold it with my other mill. It takes a little trial and error, but once you get if figured out, it works like a charm. I just stuck a lead pencil in the chuck, and used masking tape to hold a piece of cardboard to the table and did the trial and error thing, taking notes as I went. It is a super nice DRO, and I am going to put one on my present machine.
    Retired - Journeyman Refrigeration Pipefitter - Master Electrician - MakerGear M2 3D printer- 20 Watt Ray Fine Galvo fiber laser, LightObject 40 watt co2 Laser Engraver
    Las Vegas
    Default Resolution
    Not sure if I am doing this correctly, I used the reply button. If you are doing PCD circles you, or anyone else, could possibly explain what the resolution setting is for on a sino DRO. Took a very long time to install and the instructions for using it are mostly a puzzle to me. No surprise there live is mostly a puzzle to me. Thanks
    Mar 2006
    Default SDS2-2M Resolution
    Quote Originally Posted by gr8life
    After doing it over and over again, i have my resolution set in the instructions on page 2 "Setting of System" number 1, 5- x RESLN, #2 5- Y RESLN, #4 0- X- DIR, 0- Y- DIR, #8 TEST OFF... This is how my DRO reads moving the dial on the table on my Bridgeport, 0.055= 0.05500 on the DRO, moving the dial 0.250=0.22500 on the DRO, and moving the dial 1 inch the reading on the DRO is 1.00000. At one time the DRO was reading in feet, 1foot was = 1.00000 on the DRO.
